Create Force Responses
Use the Force tool to create force responses from 1D elements or constraints.
                From the Design Explorer ribbon, click the Force
                    tool.
Figure 1. - Click the guide bar selector and choose whether to create the response using 1D Elements or Loads.
 - Optional: Check the Create one response for each selected entity option.
                Select entities.
                If the option above is unchecked, selecting the first entity will create a response. If the above option is checked, a response will be created for each selected entity.
 - Optional: Make any desired modifications to the created response in the microdialog.
