Create Generic Response
Generic responses can be created two ways, by specifying a solver result file containing the desired response or by specifying a session file containing desired response evaluations.
Create Generic Response from a Session File
Create a generic response from a session file.
- Required entries
- Cell A1 must be labeled DE Responses
 - Column A: response name
 - Column B: response evaluation
 - Optional entries
- Column C: objective (min/max) or constraint operator
 - Column D: constraint value
                From the Design Explorer ribbon, click
 next to Responses and
                    select Generic Response.
             - In the Create Generic Response dialog, click the Session File tab.
                In the Session File field, click
 to browse for a session
                    file.
             - Select the desired responses and goals.
 - Click Create Response.
