Analyze
Create and edit outputs, add an analysis using the task wizard, check the model, and run the solver.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multibody dynamics models.
Add an FMU to the model or export a model as an FMU.
Use the Outputs tool to create a result output request to the solver, which writes out the requested data for plotting data.
Use the Check tool to search for any missing references in defined entities or errors in properties.
The Run Solver tool allows you to save and run the current model.
Use the Reports tool to view the report definitions of associated analysis tasks.
Reference material for the scripting interface which is a set of Tcl/Tk commands.
ON THIS PAGE
ON THIS PAGE
