poIScalarDefine SetSelectionSet
Sets the selection set with defines the entities of the result definition.
poIScalarDefine_handle SetSelectionSet modelID locator
HyperView Tcl Modify
This command, valid only in HyperView - MultiCore profile, sets the selection set which defines the entities for the result definition for the specified model.
Note: The result definition can only be modified if it is not cached.
modelID
The model identifier.
locator
Set locator string of the form" "pool_name id".
To create and use a selection set to define the result definition entities:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetModelHandle model 1
model GetSelectionSetHandle setH [model AddSelectionSet component]
setH Add "id 1"
client GetResultHandle sdefine 4 scalar
sdefine SetSelectionSet 1 "User_Set [setH GetID]"
hwi CloseStack
Returns an error code if there was an error setting the selection set and sets error condition on the session handle. See session_handle GetError.
See the HyperView - MultiCore APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
