poIPost CopyResult
Copies a result definition from another definition.
post_handle CopyResult id context notify
HyperView Tcl Modify
This command, valid only in HyperView - MultiCore profile, copies a result definition from another definition. It also returns the ID of the created result definition.
id
The result definition label ID to copy from.
context
A string indicating the context of the result to copy (scalar, tensor, vector, iso).
notify
Set to 'true' to trigger an event to update the browser, otherwise 'false'. The default value is true.
To copy the vector result with ID 5:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client CopyResult 5 vector true
hwi CloseStack
Returns 0 if there was an error copying the result and sets an error condition on the session handle. See session_handle GetError.
See the HyperView - MultiCore APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
