Adds the given node of the current/specified model to the measure.
poIMeasure_handle
AddNode
"model_id node_id"
HyperView Tcl Modify
This command adds the given node of the current/specified model to the measure.
Note: HyperView allows you to specify the measure between
several models loaded (overlaid) into the same window. This is why you have to provide the
model ID and node ID (or element ID) when you add a node or element to the
measure.
- node_id
- The node ID in one of three forms:
- "m1 n1" (A regular node)
- This option adds a node from a model with the ID = m1 and the node ID = n1. This
is the most common function you will use to create measures from scripts.
- The following two options are used mostly by the HyperView
GUI to create a measure on a section cut, or Iso surface.
- "m1 n1 n2 %1" (A param node)
- This option adds a "parametric" node from the model with the ID = m1 and the
nodes n1 and n2, and at %1 distance between n1 and n2.
- "m1 n1 n2 %1 n3 n4 %2 %3" (A param-param node)
- This option adds a "param-param" node from the following model types:
To add a node from model ID = 1, node ID = 334567 to measure
msr1:
msr1 AddNode "1 334567"
Returns 0 if successful, otherwise an error code.
