Gets a curve handle.
Gets an axis handle of a plot client.
Gets a header handle of a plot client.
Gets a footer handle of a plot client.
Gets a footer font handle of a plot client.
Gets a header font handle of a plot client.
Gets a legend handle of a plot client.
Gets a vector handle.
Gets a verticle datum handle of a plot client.
ON THIS PAGE
ON THIS PAGE
