HM_tableclear()
Clears the table of all stored items.
void HM_tableclear(void);
HyperMesh hmlib Function
See HM_tableadd() and HM_tablelookup().
None.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
For an element configuration, this function returns the number of nodes that the element uses. For rigidlinks and RBE3s, this function returns 0 because these elements have a variable number of nodes.
Returns the HyperMesh #defined type number of an entity, given its name.
Returns the name of an entity, given the HyperMesh #defined type number.
Returns the HyperMesh #defined type number of an entity, given its #defined name.
Returns the string associated with the HyperMesh #defined entity, given the type number.
Reads information from a binary file.
Writes information to a binary file.
Gets the hardware size of a float.
Gets the hardware size of an integer.
Identifies the type of machine on which the program is currently running.
Prints a message on the screen.
Tracks the version number of the translator.
Sets a pointer to a function that is called by HM_terminate().
Adds an item to the table.
Retrieves a previously stored value.
Terminates a program.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
ON THIS PAGE
None.
ON THIS PAGE
