Returns the midsurface thickness and offset values for nodes, points, or
    elements.
hm_getsurfacethicknessvalues
        entity_type
        entity_id
or
      entity_type mark_id element_method ?ambiguous_values?
      HyperMesh Tcl Query Command
      This command returns the midsurface thickness and offset values for nodes, points, or
        elements.
      An error is returned if a non-topological point or node or an element not associated to any
        surface, is given as input.
          - entity_type
          - The type of entity to query. Valid values are nodes, points and elems.
          - entity_id
          - The ID of the entity to query.
          - For nodes and points, the return result is a list with the number of list values equal
            to the number of surfaces connected to the entity. Each value is a list itself with
            three sub-values. The first value is the ID of associated surface, the second value is
            the thickness of the surface at the node or point location (-1 if not defined), and the
            third value is the thickness offset.
          - For elements, only a single list value is returned, also with three sub-values
            indicating the surface ID, the thickness at the element centroid, and the offset at the
            element centroid.
          - mark_id
          - The ID of the mark containing the entities to query. Valid values are 1 and 2.
            to the total number of surfaces connected to each entity. Each value is a list itself
            with four sub-values. The first value is the ID of the or node, the second value is the
            ID of the associated surface, the third value is the thickness of the surface at the
            node or point location (-1 if not defined), and the fourth value is the thickness
            offset.
          - For elements, the return result is a list with the number of list values equal to the
            total number of elements. For element_method 0-3, four sub-values
            indicating the element ID, the surface ID, the thickness of the element (-1 if not
            defined), and the offset of the element are returned. For
              element_method 4, the element ID is returned as the first
            sub-value. For each node of the element, a sub-list is returned containing the node ID,
            the thickness at the node and the offset at the node for the element. For example:
{elem_id1 {node_id1 thickness_1 offset_1} {node_id2 thickness_2 offset_2} … {node_n thickness_n offset_n}} {elem_id2 {node_id1 thickness_1 offset_1} {node_id2 thickness_2 offset_2} … {node_n thickness_n offset_n}} … {elem_idn {node_id1 thickness_1 offset_1} {node_id2 thickness_2 offset_2} … {node_n thickness_n offset_n}}.
          - element_method
          - Only allowed for element mark_id based usage. This determines how
            the thickness and offset values are measured for elements (ignored when the mark only
            contains nodes or points). Valid values are:
          - 0 - Thickness and offset are measured at the element centroid.
          - 1 - Thickness and offset are measured as a weighted average of the element’s nodes. If
            an element spans multiple surfaces, -1 is returned for the surface ID, thickness and
            offset.
          - 2 - Thickness is measured at the element's nodes and the minimum value is used. The
            offset value from this node is also reported. If an element spans multiple surfaces, -1
            is returned for the surface ID, thickness and offset.
          - 3 - Thickness is measured at the element's nodes and the maximum value is used. The
          - 4 - The thickness of each element node is returned. For elements that do not span
            surfaces but have nodes on shared/non-manifold edges or shared vertices, the reported
            values should all come from the same "common surface" of the element. For elements that
            do span surfaces, values for nodes on an edge/vertex between the shared surfaces, the
              ambiguous_values argument is used. For surfaces that do not have
            thickness, -1 is returned for the thickness and offset of any nodes associated with that
            surface.
          - ambiguous_values
          - Defines what to do when an element that spans multiple surfaces and a node of that
            element is on an edge/vertex between the shared surfaces. This option is only used for
              element_method=4 when a "common surface" or a "most common surface"
            cannot be determined. Surfaces that do not have a thickness are ignored and not
            considered in the calculations. If all surfaces have no thickness, -1 is returned for
            all nodes.
          - 1 - Report the average value at nodes from spanned surfaces.
          - 2 - Report the minimum value at nodes from spanned surfaces.
          - 3 - Report the maximum of value at nodes from spanned surfaces.
    Examples
      Suppose that the node with ID 100 is located on a shared edge between surfaces having IDs
        10 and 11. To retrieve the list of surfaces, thicknesses and
        offsets:
set node_thick [ hm_getsurfacethicknessvalues nodes 100 ]
      To get the surface, thickness and offset at the centroid for element
        50:
set elem_thick [ hm_getsurfacethicknessvalues elems 50 ]
       To get the surface, thickness and offset as the weighted node average for element
        50:
*createmark elems 1 50
set elem_thick [ hm_getsurfacethicknessvalues elems 1 1 ]
      To get the surface, thickness and offset for all displayed
        nodes:
*createmark nodes 1 displayed
set node_thick [ hm_getsurfacethicknessvalues nodes 1 0 ]
      Incorrect usage results in a
Tcl error. To detect
        errors, you can use the
catch
        command:
   # Handle error
