hm_collisioncheck
Performs a collision detection.
hm_collisioncheck mark_id_int_elems mark_id_pene_elems mark_id_int_surfs mark_id_pene_surfs mark_id_pene_nodes self_check reserved1 ?pair_angle? ?store_segments? ?mark_adjoining? ?topo_feature_angle? ?pair_results?
HyperMesh Tcl Query Command
Performs a collision detection using entities defined by hm_collisionentitycreate. This must be preceded by hm_collisoininit and one or more calls to hm_collisionentitycreate.
Multiple calls to this API can be made to perform different detections.
- mark_id_int_elems
 - The ID of the mark that should contain any intersected elements on output. Valid values are 1 and 2. If set to 0, no intersected elements are output. Only valid if elems or comps are used as input entities.
 - mark_id_pene_elems
 - The ID of the mark that should contain any penetrated elements on output. Valid values are 1 and 2. If set to 0, no penetrated elements are output. Only valid if elems or comps are used as input entities.
 - mark_id_int_surfs
 - The ID of the mark that should contain any intersected surfaces on output. Valid values are 1 and 2. If set to 0, no intersected surfaces are output. Only valid if surfaces or solids are used as input entities.
 - mark_id_pene_surfs
 - The ID of the mark that should contain any penetrated surfaces on output. Valid values are 1 and 2. If set to 0, no penetrated surfaces are output. Only valid if surfaces or solids are used as input entities.
 - mark_id_pene_nodes
 - The ID of the mark that should contain any penetrated nodes on output. Valid values are 1 and 2. If set to 0, no penetrated nodes are output. Only valid if nodes are used as input entities.
 - self_check
 - 0 - Do not include self checks.
 - reserved1
 - Reserved for future use. Must be set to 0.
 - pair_angle
 - The maximum allowed angle between penetrating pair normals. Meaningful values are 0.0 < angle < 90.0. Other values disable this functionality.
 - store_segments
 - Set to 1 to store the intersection lines formed when intersection entities. Only valid when mark_id_int_elems or mark_id_int_surfs are non-zero. The segments can then be visualized using *createintersectionsegments. Default is 0.
 - mark_adjoining
 - 0 - No additional marking (default).
 - topo_feature_angle
 - The angle used to identify topo faces. If set to 0.0, the global feature angle is utilized (default).
 - pair_results
 - If set to 1, detailed pair results are calculated and the hm_collisionget* and hm_collisionwriteresultsfile APIs can be used. If set to 0, detailed pair results are not calculated and the hm_collisionget* and hm_collisionwriteresultsfile APIs cannot be used (default).
Examples
*createmark surfs 1 1-10
hm_collisioninit
hm_collisionentitycreate surfs 1 0 1 0 0 0 0 0 0
hm_collisioncheck 0 0 1 0 0 0
hm_collisionend
hm_getmark surfs 1*createmark surfs 1 1-10
hm_collisioninit
hm_collisioncheck 0 0 1 0 0 0 0 90.0 1
*createintersectionsegments 0
hm_collisionend
hm_collisioninit
hm_collisioncheck 0 0 0 1 0 0
hm_collisionend
hm_getmark surfs 1hm_collisioninit
*createmark surfs 1 1-5
hm_collisionentitycreate surfs 1 0 1 1.5 1 0 0 0 1
*createmark surfs 1 6-10
hm_collisionentitycreate surfs 1 0 1 2.0 1 0 0 0 2
hm_collisionend
hm_getmark surfs 1Errors
   # Handle error
}Version History
11.0.130
