Retrieves the coordinates of interface node at the given index.
Retrieves the number of nodes in the flexbody.
Retrieves the coordinates of the node at the given index.
Retrieves the number of interface nodes in the flexbody.
ON THIS PAGE
ON THIS PAGE
