IEC
Compute Random Response Fatigue with IEC-61373.
Random Response Fatigue is evaluated at each global direction for each weld location.
- = Total damage from 1 , 2 , and 3 in each direction.
- = Total exposure time ( ).
- = Fatigue Life (maximum number of cycles of a particular stress amplitude for the material prior to failure) from the Material SN curve.
- Fatigue Material
- SN materials for Weld locations in the Points context are created/selected from the Material context.
- Query Report
- can be used to query elements for viewing Report.
- Supports only OptiStruct model/results.
- Supports only shell element evaluation (via element stress).
- Report is only available on requesting Rainflow output via Preferences.
- Stress Query is supported only for Nominal Approach.
Evaluation Distance Parameters
Parameter | Description |
Evaluation Distance | Reference distance to find the evaluation location from the
weld element at which the stress values are extracted. See Find Evaluation Positions for more information. Restriction: Only Nominal Evaluation method is
supported for IEC.
Weld Width | Width of the weld material from the web wall. This parameter is ignored if the evaluation distance is specified manually. |
Location Parameters
Material - Transverse | SN curve considered for the calculation of Fatigue Life in XX. |
Material - Longitudinal | SN curve considered for the calculation of Fatigue Life in YY. |
Material - Shear | SN curve considered for the calculation of Fatigue Life in ZZ. |
Output
- Cumulative Damage in XX, YY, and ZZ across all events and total across all three directions per location.
- Master_1D_Damage, maximum of the total damage from all locations.
- Results per location:
- Computed RMS stress per direction for all events.
- Damage per direction for all events.
- Total exposure time for all events.
- Fatigue Life/cycles for 1 for all events.
