Tensile Strength
(Rm
Listed in SN tab (default = 300 N/mm2) |
Yield Strength
(Rp
Listed in SN tab (default = 180 N/mm2) |
Elastic Modulus
(E
Listed in SN tab (default = 2e5 N/mm2) |
Strain At Break Point (A%) |
Listed in SN tab (default = 10% or 0.1) |
Normal Fatigue Limit
(σ_wzd
Listed in SN tab (default = 140 N/mm2) |
Shear Fatigue Limit
(τ_wzd
Listed in SN tab (default = 80 N/mm2) |
Number of Cycles at Knee Point, Normal Stress
(Nd_σ
Listed in SN tab (default = 1e6 cycles) |
Number of Cycles at Knee Point, Shear Stress
(Nd_τ
SN curve slope, Normal Stress
(K_σ
Listed in SN tab (default = 5) |
SN curve slope, Shear Stress
(K_τ
Listed in SN tab (default = 8) |
Fatigue Stress Factor, Fully Reversed, Normal
(fw_σ
Listed in Other tab (default = 0.4) |
Fatigue Stress Factor, Fully Reversed, Shear
(fw_τ
Listed in Other tab (default = 0.577) |
Constant, Technological Size Factor for Tensile Strength
(adm
Listed in Other tab (default = 0.15) |
Constant, Technological Size Factor for Yield Strength
(adp
Constant, Technological Size Factor @ adm
(Deff,N,m
Listed in Other tab (default = 40mm) |
Non-linear Strain Stress Factor under bending –
GJL
(KNL
Listed in Other tab (default = 1.0) |
aG
Constant for (
Kt−Kf
) ratio for Fatigue Strength Factor (
aG
bG
Constant for (
Kt−Kf
) ratio for Fatigue Strength Factor (\
bG
Listed in Other tab (default = 2400) |
Constant For Roughness Factor, Normal Stress
(aR_σ
Listed in Other tab (default = 0.22) |
Minimum permissible tensile strength constant
(Rm,N,min
Listed in Other tab (default = 400 N/mm2) |
Constant for Mean Stress Sensitivity
(aM
Listed in Other tab (default = 0.35) |
(bM
Listed in Other tab (default = -0.1) |
Compression Strength Factor, for tension, compression
(f_σ
Compression Strength Factor, Shear
(f_τ
Material Parameter Epsilon_0 (Epsilon_0) |
Listed in Other tab (default = 0.05) |
Ductility factor (q) |
Listed in Other tab (default = 0) |
