Eurocode 3 Classification Parameters (Non-Welded)
The parameters for non-welded calculations are listed in both the Assign Material tab and the My Material tab of the Assign Material dialog.
The defaults are with respect to material = steel.
The following are the parameters listed in the Assign Material tab.
Parameter | Description |
Size Effect (Ks ) | default = 1.0 |
Temperature Factor (Kt ) | default = 1.0 |
Surface Treatment (Ksur ) | default = 1.0 |
Safety Factor for Strength (Mf ) | default = 1.0 |
Loading Factor (Ff ) | default = 1.0 |
The following are the parameters listed in the My Material tab.
Detail Category for nominal (Δσc , Basic) | Listed in SN tab (default = 160 N/mm2) |
Detail Category for shear (Δτc , Basic) | Listed in SN tab (default = 100 N/mm2) |
Number of cycles at Constant Amplitude Fatigue Limit – nominal (NDσ ) | Listed in SN tab (default = 5e6 cycles) |
Number of cycles at Cut-Off Limit – nominal (NLσ ) | Listed in SN tab (default = 1e8 cycles) |
Slope before Constant Amplitude Fatigue Limit – nominal (mlσ ) | Listed in SN tab (default = 3.0) |
Slope before Cut-Off Limit – nominal (m2σ ) | Listed in SN tab (default = 5.0) |
Number of cycles at which the reference value of the fatigue strength is defined. (greyed out) – nominal (Ncσ ) | Listed in SN tab (default = 2e6 cycles) |
Number of cycles at Cut-Off Limit – shear (NLτ ) | Listed in SN tab (default = 1e8 cycles) |
Slope before Constant Amplitude Fatigue Limit – shear (mlτ ) | Listed in SN tab (default = 5.0 ) |
Number of cycles at which the reference value of the fatigue strength is defined – shear (Ncτ ) | Listed in SN tab (default = 2e6 cycles) |
Formulation
- Query Stress σxx , σyy , τxy (max and min across all loadcases)
- Find the stress ranges (max – min) = ( Δσxx , Δσyy , and Δτxy )
- Multiply Stress Range from Loading Factor Δσ
- =Δσ·γFf
- Calculate Corrected Fatigue Strength ΔσC and ΔτC
ΔσC=[ΔσC, BasicγMf]·ks·kt·ksur
ΔτC=[ΔτC, BasicγMf]·ks·kt·ksur
- Calculate Constant Amplitude Fatigue Limit ΔσD and ΔτD
- ΔσD=ΔσC(NcσNDσ)1m1σ
ΔτD=Inf
- Calculate Stress at Cut-off Limit ΔσL and ΔτL
ΔσL=ΔσD(NDσNLσ)1m2σ
ΔτL=ΔτC(NcτNLτ)1m1τ
- Calculate Permissible Number of Cycles Nperm
- For Δσ If Δσ(stress range)>ΔσD, Nperm=NDσ(ΔσΔσD)−m1σ If ΔσD>Δσ≥ΔσL, Nperm=NDσ(ΔσΔσD)−m2σ If Δσ<ΔσL, Nperm=InfFor Δτ If Δτ(stress range)≥ΔτC, Nperm=NCτ(ΔτΔτC)−m1τ If Δτ(stress range)<ΔτL, Nperm=Inf
- Component Damage
Dx=NNperm x<1.0
Dy=NNperm y<1.0
Dxy=NNperm xy<1.0
- Equivalent Damage
- D=max( Dδ,y+Dδ,xy , Dδ,x+Dδ,xy )
EN 1999-1-3:2011-11 (November
2011)
. Permission to use and reproduce information contained in the
Eurocode 3 standards was granted by DIN.
