Material Setup
<MaterialSetup type="SN">
</MaterialSetup>
| Attribute | Valid Values | Commend |
| type |
"SN" "EN" "FOS" |
Mandatory |
<MaterialSetup> tag is defined by:
| Element Tag | Valid Values | Comment |
<UserMaterialFile> |
Valid Material file path | Optional |
<EntityList> |
NA | Mandatory Compound Element |
<ExcludeSets> |
NA | Optional- Compound Element |
User-Defined Material File
The user-defined materials are optional.
<UserMaterialFile>C:/Documents/Materials.csv</UserMaterialFile>Entity List
<EntityList evaltype="Parts">
</EntityList>| Attribute | Valid Values | Comment |
evaltype |
"Parts "Sets |
Mandatory |
- For selecting Parts
<EntityList evaltype="Parts"> …. …. </EntityList> - For selecting elements in Sets
<EntityList evaltype="Sets"> …. …. </EntityList>
Entity
<entity id="1" matname="Mat_SN(1)" name="part_1” poolname="Global" FL="0" Findley="0.3" Kf="1" Offset="0" SE="0.3" Scale="1" TF="0">
</entity>A valid name must be keyed in to the matname. The material name can be specified from the user-defined materials (.csv/.xml) file or from the HyperLife Material database.
| name | Valid Part name in model file | Either name or id is Mandatory. If both are given, id will be used |
| id | Valid Part id in model file | |
| poolname | Valid poolname for the entity type | Optional Note: If no poolname is given, default poolname of the
entity will be assumed
| Scale | Valid value | NA |
| FL | 0 < Value |
| SE | 0 =< Value |
| Findley | 0 =< Value |
| TF | 0 =< Value |
| Kf | 1.0 =< Value |
| SEe | 0 =< Value |
| SEp | 0 =< Value |
| Kf | 1.0 =< Value |
The following are optional child elements of the Entity element.
Surface Finish
<SurfaceFinish Option="NONE">0.1</SurfaceFinish>
<SurfaceFinish>
Option |
"NONE "POLISH" "GROUND" "MACHINE" "HOTROLL" "FORGE" "USER" |
| Value | 0 < Value <1.0 |
Surface Treatment
<SurfaceTreatment Option="NONE">0.1</SurfaceTreatment>
<SurfaceTreatment>
Option |
"NONE" "NITRIDED" "SHOTPEEN" "COLDROLL" "USER" |
| Value | 0 < Value < 2.0 |
Temperature Factor
<TemperatureFactor Option="NONE"></TemperatureFactor>- NONE
- User Defined
- FKM
- Temperature factor "NONE"
<TemperatureFactor Option="NONE"></TemperatureFactor> - Temperature factor "USER DEFINED"
<TemperatureFactor Option="USER DEFINED" Value="1"></TemperatureFactor> - Temperature factor "FKM"
<TemperatureFactor Option="FKM"> <Temperature Option="ISOTHERMAL">150</Temperature> <Type>FINEGRAIN STRUCTURAL STEEL</Type> </TemperatureFactor>
Exclude Sets
<ExcludeSets>
<set id="" name="Set 1" poolname="User_Set" type="element"></set>
</ExcludeSets>
