View Run History and Run Status
View a list of runs saved in your home directory or the current active session.
To view all the fatigue evaluations saved in the home directory, click the
Run History satellite icon on the Evaluate tool group.
On Windows, the default home directory is C:\Documents\Fatigue\RunHistory.
On Linux, the default directory is /usr/tmp/Fatigue/RunHistory/.
The home directory can be changed from the preferences menu.
Figure 2. -
To view all the fatigue evaluations performed in the current active session,
click the Run Status satellite icon on the Evaluate tool group.
Figure 3.Figure 4.Tip: You can also view run history by clicking History in this dialog.
- Click View Current Results to open the contour results of the latest run.
