After opening a result file, you can determine which subcase(s) you want to
        translate.
            The selected subcases are displayed in the Current subcase combo box. T
                To change the subcases that are listed in the Current subcase combo box, click
                        Subcase.
                Select one or more subcases from the window and click
                        Close.
The changes you make are reflected in the Current subcase combo box.
Note: Since each subcase contains specific simulations and
                        result types, the simulations and result types displayed in the
                            HvTrans dialog change depending on the subcase(s)
                        you choose. The result contents of the selected subcase are displayed in the
                        Simulation, Result Types, Entity with Layers, Result Components, and Model
                        Components boxes.
