The spline stiffness formulation interpolates a Force versus Deflection table using
                Akima’s cubic interpolation method. For values of deflection outside the supplied
                range, the force is linearly extrapolated using the slope at the corresponding
                end-point. For each direction employing the spline-stiffness formulation, you must
                supply a Force versus Deflection table in the property file. The force is calculated
                as follows:
            Where:
                     is the displacement of Body-I relative to Body-J in
                the
                     direction after offset, scaling and coupling effects
                have been considered.
                     is the force-deflection table specified in the
                [SPLINE_STIFFNESS_xx] block in the .gbs file.
