Processing math: 100%
Multiple Preloads
The following equations show the method for computing the bushing output for multiple preloads.
Let:
  • n be the number of preloads in the test data; i be the current load case.
  • Sort the preloads Pi and renumber the preloads such that P1<P2<...<Pn .
  • xi be the filter output corresponding to the ith load case.
  • F0i be the static response of the bushing corresponding to the ith load case.
  • fi be the dynamic response corresponding to the ith load case.
Then for each preload, Pi , defines weights Wi :
And the total force is calculated as:
as you see detailed in the following figure:
Figure 3.
