Spline Stiffness Block
Spline stiffness blocks store the static stiffness properties of a bushing. The data
                is stored in a table of monotonically increasing deflections versus forces. If the
                direction block selects the spline stiffness formulation for a given direction, for
                example FZ, then the property file should contain a corresponding spline stiffness
                block for that direction, such as [SPLINE_STIFFNESS_FZ].
The following table shows the parameters stored in spline stiffness blocks.
| Parameter | Type | Dimension FX, FY, FZ | Dimension TX, TY, TZ |
| Displacement | real | [L] | [A] |
| Force | real | [F] | [F][L] |
When the property file is read the deflection and force values are converted from the units of the property file to the units of the solver model.
$---------------------------------------------------------- SPLINE_STIFFNESS_FY
[SPLINE_STIFFNESS_FY]
(SPLINE_DATA)
{  disp       force  }
   -4.48   -1538.03776
   -3.93    -933.55971
   -3.38    -506.77016
   -2.83    -227.72161
   -2.28     -66.46656
   -1.73       6.94249
   -1.18      22.45304
   -0.63      10.01259
   -0.09      -0.43487
    0.28       8.16256
    0.83      66.78761
    1.38     206.90616
    1.93     458.46571
    2.48     851.41376
    3.03    1415.69781
    3.58    2181.26536
    4.47    3922.99269
