Use Mount Stiffness when you want to approximate the structural deflection of the
        bodies that the bushing connects due to the load that the bushing carries. Mount stiffness
        is modeled as a set of linear springs and dampers in series with the bushing stiffness and
        damping, thus softening the connection between the bodies. Alternatively, you can use
        flexible bodies to model the bodies the bushing connects.
                Click Activate to add mount stiffness and damping for
                    this bushing.
MotionView adds a control state equation and
                    other elements necessary to compute the deflection and rate-of-change of
                    deflection of the bushing mounts due to the loads carried by the bushing.
                In the Stiffness Translational and
                        Rotational fields, enter positive real values for the
                    X, Y, and Z stiffness of the limits.
                    Note: Translation dimensions are force and length-1. Rotational
                        dimensions are force and length per radian.
                In the Damping Translational and
                    Note: Translation dimensions are force, time and length-1. Rotational
                        dimensions are force, length and time per radian.
