Units Block
The units block specifies the unit system used for the values in the property file. This is a mandatory block. The units must be defined for length, time, force, mass, and angle.
| Parameter | Type | Description |
| LENGTH | quoted_string | Valid length units are:
| ANGLE | quoted_string | Valid angle units are:
| FORCE | quoted_string | Valid force units are:
| MASS | quoted_string | Valid mass units are:
| TIME | quoted_string | Valid time units are:
$--------------------------------------------------------------- UNITS
[UNITS]
LENGTH = 'mm'
ANGLE = 'degree'
FORCE = 'newton'
MASS = 'kg'
TIME = 'second'
