Graph - Optimization/Convergence Summary
Figure 1. Optimization Summary Graph Button
The Graph function is available only when convergence data are available, and it provides a graphical way to visualize the convergence process.
Hovering over any point on the graph displays the iteration number and the tracked variable value and possibly grid/element identification number if applicable.
- (Lin) or (Log) switch between Linear and Log-Linear plot. In Log mode the sign of traced variable is removed (all values are treated as non-negative)
 - (<) and (>) zoom plot on the left or right range of values
 - (x) reset to full range of values
