Watertight Cabin
- Extract external surface through a script:
- Stamped parts (parts with continuous thickness – doors, hood, cabin
floor, and so on)
- Script identifies one side of thickness surfaces with maximum area
- After surfaces are extracted, remove unnecessary faces
further such that opposite part boundary edges faces each
otherFigure 1.
- Non-stamped parts (mirrors, plastic parts, and so on)
- Manually extract wetted faces
- For some complex parts, you might have to trim some surfaces
in order to extract clean wetted facesFigure 2.
floor, and so on)
- Generate facets/mesh on exterior surfaces:
- Generate faceted mesh on extracted wetted faces (use rigid body mesher – maximum size 20 mm, minimum size 0.1 mm, maximum deviation 0.1 mm)
- Rigid body mesher captures all fillets and curvature with optimum number of triads
- Make sure generated facets are not deviating much from geometryFigure 3.
- Cabin floor parts can be meshed with constant size of 8 mm
- Close holes:
- After facet/mesh generation, fill holes using the Fill Hole/Gap utility
- Select all components
- Define maximum width (generally 50 fills up all holes)Figure 4.
- Fuse gaps:
- Use fuse tool to connect parts with wetted faces
- Upper body parts fuse:
- In the below example, wetted faces are extracted so they have gaps/proximity between them
- The option “Fuse free edges only” is used
- Fuse threshold depends on maximum gap between parts. Generally, it varies between 6-12 mm
- You can select multiple source and target parts for one fuse
operationFigure 5.
- Fuse cabin floor parts:
- Here parts are either in proximity, overlapping or
intersectingFigure 6.
- Deactivate the “Fuse free edges only” option for such parts
- Fuse threshold depends on maximum gap between parts. Generally, it varies between 8 - 10 mm
- Source parts will move to target, so select source and target accordingly
intersecting
- After fusing if there are any bad elements, manually fix them at the end
- Generate apron faces for large openings:
- If there is a big gap between cabin floor and upper body, create apron faces first
- Use Fill Hole/Gap tool > Patch fill > Select surrounding nodes and create patch
- Fuse upper body with cabin floor
- Perform checks for watertight cabin:
- Check for free edges, non-manifold edges
- If free edges are valid, mark the corresponding component with “Baffle” name
- Check and fix normal of the cabin
