Cut and Stitch
Use this process to replace the upper body of the model with a modified design for repeated design iterations. This process uses Inspire Studio to generate/modify the upper body design and HyperMesh to switch/replace the designs as needed.
Process
- Import the upper body as an STL from Inspire Studio. Check for and delete any duplicate
elements.Figure 4.
- Equivalence
non-conforming elements so there is only one edge along the outer boundary
of a surface.Figure 5.
- Import the cabin floor and apron.Figure 6.
- Ensure both the upper body and the cabin floor/apron are the same scale and intersect them as desired.
- Scale both models to 1000*mFigure 7.
- Boolean the surfaces together.Figure 8.
- Trim unnecessary surfaces from the model.Figure 9.
- Scale to meters.
- Import the powertrain, wheels, mirrors, and so on.Figure 10.
