Basic model - Current source
1. Positioning and objective
This export allows the users to build a model in Altair® Flux® 3D, static application to perform magneto-static, and multi-static simulations.
User inputs like, line current and control angle are predefined to get quick access into Flux® 3D environment for performing computations.
The resulting model is fully parameterized, and it is built in Flux® 3D environment, static application.
Working point – I, Ψ, N - Illustration |
The following section describes all the user inputs to initialize the exported model.
All these parameters can be modified in Flux® 3D environment, if needed.
