Monitor the status of your jobs, filter the job view, view job details, monitor memory and core utilization, view
a list of job files, or perform job actions.
Add or remove list attributes in the file and job listing table.
There are more than thirty (30) job attributes and more than ten (10) file
attributes that can be displayed in the Job Listing and File Listing. This provides the
flexibility to select the job information or files that is pertinent for your work
environment while being able to dismiss information that would otherwise clutter up the
display.
Click available in the column header of Files, Jobs, Input, Output,
and Running Folder tabs.
For example, if you have selected in the Jobs tab, then the Job
Select Columns list is displayed.
Figure 1. Job Select Columns
For example, if you have selected in the Files tab, then the
File Select Columns list is displayed.
Figure 2. File Select Columns
Note: The File Select Columns displayed is same
for Files, Input, Output, and Running Folder tabs.
Select the attribute(s) to be added to the display by enabling the check box of the attribute.
For example, if you have added CPU % Used attribute then the job list will
be updated.
