Upload a File or Folder
Upload a file or folder stored on your local machine to the remote server.
  1. Click the Files tab located in the upper left-hand of the page.
  2. Using the file system tree on the left, navigate to the location where you want to upload the file.
  3. Click + Upload.
    Upload a File
    Figure 1. Upload a File
  4. Select File from the drop-down menu.
    Upload Option
    Figure 2. Upload Option
    Note: Select Folder if you want to upload a folder.
    A File Upload dialog box is displayed.
  5. Browse and select the file to upload.
    If you are uploading a zip file, an option is provided to extract the contents of a zip file.
    Unzip File Option
    Figure 3. Unzip File Option
    Note: This option is displayed when you are uploading a single zip file.
    Note: Select Don't Ask Again to disable the confirmation message.
  6. Click Yes to extract the contents of the zip file.
  7. Click Open.
    You can also drag the file from your local system to the folder to upload.
    Drag the File to Upload
    Figure 4. Drag the File to Upload
    The file starts to upload. A progress bar is displayed in the lower right-hand side of the page indicating the progress of the upload. A notification message is displayed when the upload is complete.
    Tip: When you hover over the progress bar, you will get an option to terminate the file upload.
