Unpublish a Global Application Definition
Remove a published application definition from the global application definition list.
Note: Only administrator can remove the global application definition.
The administrator who has published the application definition can remove the application definition from the global list.
  1. Click .
  2. Select App Composer.
    The Applications panel lists all the application definitions that is created, shared and published.
    App Composer
    Figure 1. App Composer
    The indicates that it is a shared application definition.
    The indicates that it is a published application definition which is global app def available to all the users.
  3. Click next to the application definition that you want to unpublish.
  4. Select Unpublish in the context menu.
    Unpublish Application Definition
    Figure 2. Unpublish Application Definition
    A notification is displayed.
    The application list is updated and
    is removed.
    Applications List
    Figure 3. Applications List
