Split Subsystems
  1. From the Model ribbon, click the Split tool.
  2. From the guide bar, select an SEA Subsystem to split.
  3. Pick Node 1 and Node 2.
    Figure 3.
  4. From the guide bar, click Split.
  5. Area, property, and material information is updated, but you must reapply Noise Control Treatment (NCT) details. This prevents errors when applying NCT multiple times.
  6. The component is split based on the node selection.
    Figure 4.
