Define Surface Plots
In this tutorial, you will learn how to create surface plots.
![](../../../images/icons/icon_define.png)
The Define panel enables you to create new Surface plots. New data can be mathematically defined using the program's curve calculator, or entered as values.
![](../../../images/hypergraph/define_curves_panel_3d.bmp)
