Plot and Edit Polar Plots
In this tutorial, you will learn how to create polar plots from a data file and add polar plots by using mathematical functions.
Click Create Curves by File dialog.
to open theUse the Create Curves by File dialog to constructs multiple curves and plots from a single data file. Curves can be overlaid in a single window or each curve can be assigned to a new window. Individual curves are edited using the Define panel.
![](../../../images/hypergraph/ribbon_hypergraph_polarchart.png)
Figure 1. Polar Chart Ribbon
![](../../../images/icons/icon_define.png)
Existing curves can be edited individually and new curves can be added to the current plot using the Define panel. The Define panel also provides access to the program's curve calculator.
![](../../../images/hypergraph/file_as_source_polar.bmp)
Figure 3.
