Data Query - Waterfall Plots
In this tutorial, you will learn how to use the Data Query panel for Waterfall plots, and plot the orders in the HyperGraph window
The Data Query panel uses vertical cutting surfaces for viewing and plotting non-planer cross sections. Surfaces can be defined by math expressions, specifying orders, and selecting points on the waterfall plot or 3-D surface plot.
