HyperWorks
HyperWorks
2023.1
  1. Home
  2. Connectors
  3. Realizations
    View details for different types of realizations.
  4. Point Connector Realization Types
    A list of realization types that can be specified for point connectors.
  5. plink (connector position)
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Meshing and Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • PhysicsAI
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
  • Collaboration Tools
Index
HyperWorks
2023.1
HyperWorks
  • What's New
    View new features for Altair HyperWorks 2023.1.
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
    • Connector Browser
      Use the Connector Browser to view and modify connectors in the current model.
    • Define Connector Controls
      Use the Control Manager to create and edit the various types of controls that will be used later when realizing connectors.
    • Create and Realize Connectors
      Use the tools in the Create tool set to create connectors, assign controls, and realize.
    • Apply Mass
      Create a dummy connector entity to add mass to a part, or create areas of mass to represent parts not present in the CAD or FE data.
    • Connector Quality Check
      Use the Quality controller to perform various checks on connectors and realized FE.
    • FE Absorb Connectors
      Use the FE Absorb tools to create connectors from existing mesh that meet specific types of realizations.
    • Realizations
      • Point Connector Realization Types
        • Beam (Contact)
          This realization creates beam elements between the shells and/or solid elements, connecting them using a contact definition.
        • Beam (Rigid)
          This realization creates bar (CBAR) elements between the shell and/or solid elements and then connects the two using RBE3 elements.
        • CFAST (General)
          This realization creates CFAST elements between the connecting links.
        • CGAP (G)
        • Cweld (General)
          This realization creates weld (cweld) elements to connect the connector links.
        • Fastener (Coincident)
        • Fastener (Nodes)
        • FEMFAT
        • Hexa (Contact)
          This realization creates hexa elements between shell and/or solid elements connecting them with a tie contact definition.
        • Hexa (HAZ)
          Use this realization to create hexa clusters between shell components.
        • Hexa (Imprint)
          This realization creates one hexa cluster per connector and realizes a node to node connection to the linked shell meshes by adjusting it (shell coating).
        • Hexa (Rigid)
        • HiLock
        • Mastic
        • penta (mig)
        • pie (rigid spider)
        • plink (connector position)
        • plink (middle of the gap)
        • rbe3 (Load Transfer)
          Use the RBE3 Load Transfer realization to create MPCs using RBE3 elements between the nodes of shell-shell, shell-solid, or solid-solid groups by using spot connectors.
        • rigidlnk (midnode)
        • Spring (Rigid)
          This realization creates spring (CBUSH, CELAS1, CON3D2) elements between the shell and/or solid elements and then connects using Rigid elements (RBE2, RBE3, DCOUP) elements.
      • Fastener Connector Realization Types
        A list of realization types that can be specified for fastener connectors.
      • Line Connector Realization Types
        A list of realization types that can be specified for line connectors.
      • Area Connector Realization Types
        A list of realization types that can be specified for area connectors.
    • Element Organization
      Organize elements into connector groups.
    • FE Configuration File
      The FE configuration file (feconfig.cfg) is used to define custom welds such as ACM (Area Contact Method) and other special types.
    • Attachments and Connectors
      Attachments are an entity to facilitate the ease of joining subsystems.
    • Connector Tools
      Use the Connector tools to further define connections between components.
    • CAD Abstraction
      Abstract information incoming from the CAD hierarchy to robustly create connectors.
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
HyperWorks
HyperWorks
2023.1
  1. Home
  2. Connectors
  3. Realizations
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
Restriction: Only available in PAM-CRASH 2G.
Creates a PLINK element. The PLINK is created at the connector location.
This realization uses the prop_plink.tcl property script.
