Connector Quality Check
Use the Quality controller to perform various checks on connectors and realized FE.
The Quality controller is used to determine if the model contains duplicate connectors or if the realized elements meet the quality requirements such as the length of 1D elements and their perpendicularity to the shells they connect.
Duplicates
Finds all duplicate connectors (two or more connectors that are located within the set tolerance and connect the same link entities (Parts) are considered duplicates).
- Selection
- Determines whether the check will be performed on all connectors/attachments, or on a selection of connectors/attachments.
- Entity
- Connector or Attachment entity selection.
- Tolerance
- Specifies the distance between two or more connectors to be considered duplicate.
- Ignore Links
- Do not take links into consideration during check (number of links, linked entities and so on).
- Overlap %
- Specifies the percentage of overlap for two or more connectors to be considered duplicate (Field appears for Line/Spot Line Connectors only).
- ID Manager
- Determines which connector(s) will be deleted with the Fix action.
- Fix
- Deletes the duplicate connector(s) according to ID Manager.
Figure 2. Duplicate Connectors
Combine
Finds all adjacent connectors (two or more connectors that are located within the set tolerance and connect different parts/components).
Figure 3.
- Selection
- Determines whether the check will be performed on all connectors, or on a selection of connectors.
- Entity
- Connector entity selection.
- Tolerance
- Specifies the distance between two or more connectors to be considered adjacent.
- ID Manager
- Determines which connector(s) will be discarded with the Fix action.
- Fix
- Combines the adjacent connectors according to the ID Manager.
Find Too Long
Finds all connectors whose length exceeds the length specified by the set tolerance.
Figure 4.
- Selection
- Entity
- Tolerance
- Specifies the deviation from the “correct” length.
- Length Type
- Specifies whether the average thickness of the links or a user defined value will be used.
- Length
- A user defined value as the “correct” length.
Figure 5.
Find Too Short
Finds all connectors whose projection length falls short of the specified length by the set tolerance.
Figure 6.
- Selection
- Entity
- Tolerance
- Length Type
- Length
Find Too Long or Short
Finds all connectors that deviate from the specified length, by the set tolerance.
Figure 7.
- Selection
- Entity
- Tolerance
- Specifies the allowed deviation from the “correct” length.
- Length Type
- Specified whether the average thickness of the links or a user specified value will be used.
- Length
Find Too Close to Edge
Finds all connectors whose distance to a free/feature edge is smaller than the set distance.
Figure 8.
- Selection
- Entity
- Feature Type
- Determines whether a feature edge, a free edge, or both will be considered during the check.
- Feature Angle
- Specifies the maximum angle between elements to be considered a feature.
- Distance
- Specifies the distance from the free/feature edge(s).
- Fix Action
- Moves the connectors away from the free/feature edge(s).
Collinearity
Checks if the links of a connector are parallel to each other, considering the Max Feature Angle. If the first check is satisfied and the Diameter is used, a check is performed to ensure that the parallel area is big enough for a realization with the set diameter.
Figure 9.
- Selection
- Entity
- Max Feature Angle
- Specifies the maximum angle between the links of a connector to be considered parallel.
- Diameter
- Specifies the diameter of the realization that needs to fit in the parallel area.
Figure 10. Maximum Feature Angle for Collinearity Check
