Constraints
Introduction
Constraints | Required information |
Physical constraint |
Constraints on 2D faces volume |
Symmetry constraint (defined by direction) |
In this case, the direction of the symmetry axis is
(0.5;0.5).
Symmetry constraint (defined by angle) |
In this case, the angle of the symmetry axis is
45°.
Double symmetry constraint (defined by direction) |
In this case, only one of both axes must be defined,
choose between (1;0) for X axis or (0;1) for Y axis.
Double symmetry constraint (defined by angle) |
In this case, only one of both angles must be defined,
one can choose between 0, 90, 180, 270, ….
