Selection, editing of circuit components in the circuit editor context
Introduction
This section presents the various functions of the electric circuit editor context connected with the selection and editing of the components of the electric circuit.
These manipulations can be done starting from:
- The Graphic sheet
- The Data tree
- The Circuit menu
Graphic selection cursor
In the graphic zone, the selection of circuit
components is carried out with the mouse which has this cursor  by default.
 by default.
Selection modes by component
Each component has its own selection mode appropriately associated to an icon to be commanded.
Concerning the components, there is a selection by type, which permits to choose in a selection only components of the same type.
Concerning the connection wires there are different modes of selection. The wires consist of an assembly of segments. It is therefore possible to select:
- a segment
- an assembly of segments (connection)
- an assembly of connections (potential)
The different modes of selections of wires are presented in the table below:
| Mode of selection | Icon | Selection |
| Segment |   | of one segment |
| Connection |   | of the assembly of segments between two connecting points or between one connecting point and a component terminal or between two component terminals |
| Potential |   | of the assembly of elements with the same potential (connections, connecting points) |
By default, the active mode of selection is the Segment mode.
Select and Edit an component from the Data tree
To select and then edit a component of the electric circuit starting from the Data tree :
| Step | Action |
| 1 | Select the component in the Data tree :
| → | The element is highlighted |
| 2 | Edit the component in the Data tree :
 or
| → | The dialogue box corresponding to the electric component is opened. The user can characterize or modify the component of the electric circuit |
Select and Edit an electric component by graphic sheet
To Select and then edit a component of the electric circuit starting form the Graphic sheet :
| Step | Action |
| 1 | Select the component starting from the graphic sheet:
| → | The graphic component is shining |
| 2 | Edit the component starting from the graphic sheet:
 or
Select an assembly of electric components
To select an assembly of components (starting only from the graphic zone):
| Step | Action |
| 1 | In the graphic sheet choose the zone to select:
| → | The graphic elements inside the selection zone appear shining |
| 2 | To add another zone to the selection
| → | The user can then consider a manipulation of this selection group (copy/paste, slide, rotate…) |
Select an assembly of electric components of the same type
To operate a selection of an assembly of electric components of the same type:
| Step | Action |
| 1 | Activate the by type selection by clicking on one of the
                        modes of selection of component (for example  ) |
| → | A dialogue box Type selection is opened |
| 2 | Choose the desired type of component |
| → | The dialogue box must remain open |
| 3 | In the graphic sheet choose the zone to select:
| → | Only the graphic components of the same type chosen for step 2 at the interior of the selection zone appear shining |
| 4 | Add another zone to the selection
| → | The user can then consider a manipulation of this selection group (copy/paste, slide, rotate…) The user can equally consider the Edit array command for the selection consisting in components of the same type |
Select all
To select all the electric components present on the sheet:
- Use the keyboard shortcut Ctrl + A
