Creation of connections in the circuit editor context
Introduction
The creation of the connections is done by means of the Cabling mode, which can be
            activated in the Circuit or by the icon  or by the keyboard shortcut W.
Tracing of connections
The tracing of the connections is done like the tracing of no matter what trait on a drawing page.
This operation comprises:
- the choice of a starting point and of an arrival point
- the choice of a path between these points
- the addition of junctions (connecting points), if necessary.
The addition of connecting points is necessary to materialize the intersection of the two wires (with electric contact).
Tracing a connection
Firstly we place ourselves in the case when we desire to "draw a wire" starting from an existing point: extremity of a connection, connecting point or connecting terminal of a component.
To trace a connection:
| Step | Action |
| 1 | Select the cabling mode (icon  ) |
| 2 | Choose one of the following actions:
| 3 | To trace one (or some) segment(s) :
| 4 | Choose one of the following actions:
| 5 | Choose one of the following actions:
Modification of the components terminals
When a component terminal is connected it is automatically modified and changed by the name of the equipotential point corresponding to the created connection.
Impossible connections
Certain connections are impossible from a physical point of view, such as for instance the short-circuit of a component terminals.
The circuit editor recognizes these bad connections and forbids creating them.
This is translated by:
- the appearance of the cursor  , signifying the interdiction of connection , signifying the interdiction of connection
- the connection appears in red
