Solve a mono-step scenario
Definition: reminder
A mono-step scenario is used to solve a non-transient application within a non-parametric analysis.
A mono-step scenario is a scenario that comprises a single computation step.
Situation
In this paragraph we are interested in the following situation. The user chooses to solve the Flux project in its current state. The geometric parameters and the possible I/O parameters are set to their reference values.
Solve
To solve a Flux project in its current state (mono-step scenario with reference values), follow the steps below:
| Step | Action |
| 1 | Activate the Solve command |
| 2 | Click on Solve with reference values |
| 3 | Click on OK |
| → | The REFERENCEVALUES scenario is created. The computation step is solved. |
Complements for solving process
If the user chooses first to change some values of geometric parameters and/or I/O parameters, this must be done before activating the Solve command.
The modification can be done:
- either directly (modification of the reference values)
- or by means of a scenario (see mono-value control in § Solve a parametric multi-step scenario).
