Data Export to HyperView and HyperGraph
Introduction
Export to HyperView enables to view and postprocess Flux results in HyperView or HyperGraph during or after the solving process. This permits to benefits from HyperView or HyperGraph advanced postprocessing capacities.
Export function can be accessed by scenario box. This process generates an .h3d file.
| Export via scenario | Export via Import/Export context | |
| Aimed softwares | HyperView / HyperGraph | OptiStruct / AcuSolve/ ... |
| Support | Full domain of the project | Imported mesh / Flux entities of the same mechanical set |
| Global quantity | One or several | Only one |
| Scenario step | All steps | Single step or all steps selection |
| Visualization | During of after solving process | After solving process |
Export of .h3d file in Flux
- Chose a name for the .h3d file that will contain the data
- Chose the quantities to be computed on the device
Import of .h3d file in HyperView
- In order to view the results computed by Flux on nodes, Use
                            corner data option must be checked:
- In order to visualize movement in HyperView, chose Set Transient
                            Animation Mode via the following icon:
Limitation
- Scenario with distribution
- Remeshing during solving process, ie.:- Geometric parametric scenario
- Adaptive solver
- Compressible mechanical set In such case, the export is realized on the device with the exception f the region including the compressible mechanical set.
