Placement and deletion of Tube Points
Placements of the Tube Points
Having imported an image, it is sufficient to
click on the icon  to be able to
position the Tube Points
on this image:
 to be able to
on this image:
Deletion of the Tube Points
To delete some Tube Points, it is sufficient to select them and
            then to click on the icon  or to press the “Delete” key of the keyboard.
