Import and possible manipulations on an image
Import of an image
Click on the icon  then select an image
of the JPG, GIF, PNG, BMP or TIF type.
The opening by the user of a second image automatically generates the deleting of the first one.
Automatic resizing of the workspace
If the imported image is bigger than the previously defined workspace, Flux PEEC proposes to the user to enlarge this workspace to the image size:
Final result
Here is what it is obtained:
| Modifications | Actions |
| Deleting of the image | Click on the icon   |
| Different possible zooms | Click on the icon  Click on the icon  Click on the icon  Click on the icon  |
| Visibility of the workspace | Click on the icon  to make the
                        workspace visible or invisible |
| Visibility of the image | Click on the icon  to make the image visible
                        or invisible |
| Creation of Tube Points | Click on the icon  to insert the
                           Tube
                           Points on the image (see next paragraph) |
| Visibility of Tube Points | Click on the icon  to render the
                        Tube Points visible or invisible |
| Visibility of coordinate system | Click on the icon  to render the
                        coordinate system visible or invisible |
| Rotation of the image | Click on the icon  to pivot the
                        image in trigonometric direction. In function of the desired angle, Flux
                        PEEC will propose to the user to readapt the dimensions of the workspace so
                        that the image should be totally recovered. |
| Modifying the image scale | Click on the icon  in order to
                        resize the image. To this end, a distance between two points must be defined
                        and a new value must be allotted to this distance. The image can thus be
                        enlarged or diminished. If it is enlarged, the workspace also enlarges so as
                        to include the image. If the image is diminished, the workspace remains
                        unchanged. |
| Delete a selection | Click on the icon  to delete a
                        selection |
| Mirror effect | Click on the icon  Click on the icon  |
| Resizing the image | Click on the icon
 to zoom in
 to zoom in to zoom out
 to zoom out to visualize
                           the entire workspace in the window
 to visualize
                           the entire workspace in the window to define a window zone in which you will have to zoom
                           in
                           in to give a mirror effect to the image along a vertical
                           axis
                           axis to give a mirror effect to the image along a horizontal
                           axis
                           axis to resize the image by manually returning to the new
                           dimensions or by moving to a multiplicative factor with respect to the
                           existing dimensions:
