Construction tools: translation
Translation
The sketcher mode of construction « Translation » permits the user to displace an assembly of entities accurately along a vector defined by a delta X and a delta Y.
Access / Cursor
The different accesses and the personalized cursor for this mode of creation are presented in the following table:
| Acces | Cursor |
| by icon:   |   |
| by menu: |
Dialog box
After the activation of this mode, a dialog box containing all the necessary fields and options to apply a translation will appear.
| Description | Illustration | |
| Graphic selection | Permits to get information on the list of entities to be translated by selecting them graphically* |   |
| Dx | Definition of the vector of translation : Delta on the abscissas between the origin position and the final desired position | |
| Dy | Definition of the vector of translation : Delta on the ordinates between the origin position and the final desired position |
*It is possible to deselect the entities graphically or by using the button Delete.
