Magneto Static: solved equations (vector model 2D)
Introduction
The vector model is the general model proposed for 2D applications.
This model is used by default (automatically) by:
- the 2D solver of Flux 2D
- the 3D solver of Flux 3D for solving a 2D application
Equation solved with vector model (2D applications)
The Gauss law for magnetism,  , allows the introduction of a magnetic vector potential
, allows the introduction of a magnetic vector potential  , such as:
 , such as:
The equation solved by the finite elements method in a Magneto Static application is written:
where:
- [νr] is the tensor of the relative reluctivity of the medium
               ν0 is the magnetic reluctivity of the vacuum, ν0 = 1/μ0 = 1/(4 π 10-7) (in m/H)
                is the vector potential (in Wb/m) is the vector potential (in Wb/m)
                is coercive magnetic field (permanent magnets) (in
A/m) is coercive magnetic field (permanent magnets) (in
A/m)
                is the density of
               current source (in A/m2) is the density of
State variable, vector model (2D applications)
The state variable in 2D applications is the magnetic vector potential  .
The magnetic field B is written :
and :
In 2D problems, the  vector has a non null component, the normal component to the plane of figure; let
               An (or Az)
               An (or Az)
The magnetic field B is written:
The state variable, dependent on the problem type, plane 2D or axisymmetric 2D, is given in the table below.
| Type of the problem | State variable | Notation (in Flux 3D) |
| plane | An | AN1* |
| axisymmetric | rAn | RAN1* |
