Magneto Static: solved equations (scalar model)
Introduction
The scalar model is a general model proposed for 3D applications.
This model is used by default (automatically) by the 3D solver of Flux 3D to solve 3D applications.
Equation solved in the scalar model (3D)
The equation  allows
            introducing different magnetic scalar potentials ϕ, such as:
 allows
            introducing different magnetic scalar potentials ϕ, such as:  . The term
. The term  is the non-rotational part
            of the field
            of the field  (
 (  ), while the term
), while the term  can be rotational or
            null.
            null.
             can be chosen in
different ways and a different choice of
 can be chosen in
different ways and a different choice of  leads to
a different scalar potentials. Flux 3D has different magnetic
formulations that use different scalar potentials. To each region
of the problem a formulation is associated and, consequently, an
equation.
 leads to
equation.
The general form of the equation solved in scalar model by the finite elements method in a magnetostatic application is written:
where:
- [μr] is the tensor of the relative permeability of the medium
- μ0 is the permeability of the vacuum; μ0 = 4 π 10-7 (in H/m)
- ϕ is a magnetic scalar potential (in A); there are two potentials written ϕtot and ϕred
                is a term
                  corresponding to sources is a term
                  corresponding to sources(field source or electric vector potential (in A/m)
                is the remanent
magnetic flux (permanent magnets) (in T) is the remanent
The proposed formulations…
The three formulations proposed in the scalar model correspond schematically to the following three situations:
- there are no current sources
- the current sources are of non-meshed type
- the current sources are of meshed type
The solved equations in these three situations are presented below.
Separately used, each of these formulations has significant limitations; used in a coupled manner, they form an efficient general model.
The scalar total potential (3D)
The total magnetic scalar potential , ϕtot, is used when there are no current
            sources. The current density  is null. This case corresponds to
 is null. This case corresponds to  in the general equation of
            the scalar model.
            the scalar model.
The intensity of the magnetic field  has the expression:
 has the expression:
and the solved equation is:
The state variable is the total magnetic scalar potential: ϕtot
This variable is written V1 in Flux.
The reduced scalar potential with respect to Hj (3D)
The reduced magnetic scalar potential with respect to Hj,
                  ϕredHj, is used when the current sources are of the non-meshed
            type. This case corresponds to  in the general equation of the scalar model, with Hj
            analytically computed by the Biot and Savart formula (see § Magneto Static: non-meshed sources (3D specific) ).
The magnetic field strength  has the
expression:
 has the
expression:
and the solved equation:
The state variable is the total magnetic scalar potential with respect to Hj: ϕredHj
This variable is written V1R in Flux.
The reduced scalar potential with respect to T0 (3D)
The reduced magnetic scalar potential with respect to T0,
                  ϕredTo, is used when the current sources are of the meshed type.
            This case corresponds to  in the general equation of the scalar model. The quantity
 in the general equation of the scalar model. The quantity  satisfies the relation
                , where
 , where  is the current density in
            the meshed region of field sources.
expression:
 has the
expression:
Thus, the state variables are:
               the reduced magnetic scalar potential with respect to T0: ϕredTo This variable is also written V1R in Flux
- the electric vector potential  , variable non directly accessible in Flux , variable non directly accessible in Flux
