Definition of a polarization law
Introduction
A polarization law is a law that connects the difference of electric potential and the current density at the level of an electrochemical interface (electrode/electrolyte).
Polarization law
A polarization law is defined by a series of values: (normal component of the current density Jne / difference ΔV of electric potential)
Current density:
The normal component of the current density at a point (  ) is considered positive
            when the current passes from the electrolyte towards the cathode. The normal unit vector
                is directed from
 is directed from
Difference of electric potential:
The difference ∆V of the electric potential represents the electric potential of the electrolyte at a point very close to the cathode, when that of the cathode is null:
where:
- Ve is the electric potential of the electrolyte
- Vc is the electric potential of the cathode
The values of the normal component of the current density Jne must be strictly increasing.
The values of the differences ΔV of the electric potential must be: either strictly increasing, or strictly decreasing.
Modes of definition
You can define a polarization law in two different ways:
- directly: defining the couple of values in a dialog box
- indirectly: defining the couple of values in a text file
The file text must meet the following requirements :
- only two values per line, separated by a space
- no title
