Definition of regions for an incomplete computation
Introduction
The simplified or incomplete computation is a computation carried out under the following conditions:
- the computation is accomplished without taking into account of the current density in the structure
- the structure introduced in the electrolyte is represented by means of boundary conditions
Volume region
Volume regions are gathered in the table below.
| A volume region… | is a material region which enables the modeling… |
| electrolytic conducting | of a conducting medium (resistivity ρ) |
| inactive | of an insulating medium |
Face region
Face regions are gathered in the table below.
| A face region… | is a BC that enables one to impose… |
| electrochemical interface | conditions at the interface “electrolyte – cathode” by the intermediate of a polarization law |
| imposed potential | a potential (varying formula / spatial formula) (sacrificial anode) |
| imposed normal current density | a normal current density* (varying formula / spatial formula) (active anode) |
 is directed from the face region towards the
            electrolyte.
            electrolyte.Line region
Line regions are gathered in the table below.
| A line region … | is a BC that enables one to impose … |
| imposed normal current density | a radial current density* (varying formula / spatial formula) (active anode) |
 is directed from the line region towards the
               electrolyte.
               electrolyte.Point region
Point regions are gathered in the table below.
| A point region… | is a BC that enables one to impose… |
| imposed potential | a potential in a point |
