Power balance (Steady State AC Magnetic application)
Introduction
In Steady state AC magnetic application, the computed physical quantities vary sinusoidally with time (at a given frequency). They are expressed by means of complex images.
The power balance allows the access to the powers dissipated by the system.
Sub-systems definition: reminder
The system comprises one or more sub-systems like the one presented in the figure below.
Computation / results
The values calculated for each of the sub-systems and for the period T=1/f:
- the dissipated powers (mean values over a T period)
Dissipated powers
For the dissipated powers, a summary of the computed quantities is presented in the table below.
| Sub-system | Losses (instantaneous) (in W) |
| Internal |
| Electrical | Losses by the Joule effect (resistive components):
                                 with S defined by:
                                 with S defined by:
                               (with I peak)
 (with I peak) , with S
                           defined by:
, with S
                           defined by:  (with U and I peak)
 (with U and I peak)
