Power balance (Transient Magnetic application)
Introduction
In Transient Magnetic application, the resolution is carried out for each time step. The power balance is carried out for a time interval defined by the user.
Sub-systems definition: reminder
A system comprises one or more sub-systems as the one presented in the figure below.
Computation / results
For each of the sub-systems, as well as for the time interval defined by the user (Δt = t2 - t1), the following quantities are computed:
- the stored energies (instantaneous values, for t = t1 and for t = t2)
- the dissipated powers (mean values over the time interval Δt)
Stored energies
For the stored energies, a summary of the computed quantities is presented in the table below.
| Sub-system | Stored energy (at a moment t) (in J) | |
| Internal | Magnetic energy stored in the computation domain:  |   |
| Internal mechanical energy: | ||
| Electrical | Energy stored in the coils: Energy stored in the capacitors: |  |
| Mechanical | External mechanical energy
Dissipated powers
For the dissipated powers, a summary of the calculated quantities is presented in the table below.
| Sub-system | Losses (instantaneous values) (in W) | Losses (mean values) (in W) |
| Internal | Losses by Joule effect in solid conductors  Losses by Joule effect in stranded conductors |   |
| Internal mechanical losses:
| Electrical | Losses by Joule effect (resistive
                        components): |  |
| Mechanical | External mechanical losses:
 , with
 , with
                         (translating motion)
                           (translating motion) (rotating motion)
                           (rotating motion) (translating motion)
                           (rotating motion)
