About orientation of magnets
Definition
Before discussing the magnet orientation, the concept of magnet in Flux must be defined specifying the point of view it is related to.
- for magnet manufacturers:- a material for an isotropic magnet is a material with identical magnetic characteristics in all directions; the magnetization process of the magnet will lead to the same result in any direction
- a material for an anisotropic magnet has a preferred direction of magnetization; it will be magnetized in this direction
- in the Flux software:a material of the magnet type is a magnetized magnet ; it has a preferred direction - its direction of magnetization
Consequence
A magnet must be oriented in the region it is affected in.
Various models
The various types (models) provided for the magnets are presented in chapter Materials: principles (§B(H) law: models for hard materials).
The distinction between the unidirectional model and the vector model is explained in the two tables below:
| In a model of the “unidirectional” type the mathematical model and the direction of magnetization are dissociated | ||
| Definition | Use | |
| Module of Br | Direction (in a plane XOY)
 | A single material can be used for definition of several regions (with different directions of magnetization) |
| In a model of the “vector” type (linear approximation only) the mathematical model and the direction of magnetization are associated | |
| Definition | Use |
 | It is necessary to create the same number of materials and/or coordinate systems as the regions |
Orientation of unidirectional magnets: principle
For a unidirectional magnet, there is no information (at the level of the definition of the material) on the direction of magnetization.
To “orient a unidirectional magnet in a region”, one must:
- choose the type of orientation
- define the characteristics of this type
The principle of orientation for a unidirectional magnet in a region is presented in the figure below. (The basic plane is a XOY plane)
| Type of orientation | Scheme | Description characteristics | |
| Unidirectional |  |
| Radial positive / negative |  |  |
| Orthoradial positive / negative |  |  |
Orientation of vector magnets: principle
For a vector magnet, the direction of magnetization is defined in a virtual coordinate system.
To “orient a (cartesian, cylindrical, spherical) vector magnet in a region”, one must choose a coordinate system for orientation (real coordinate system).
The principle of orientation for a vector magnet (cartesian) in a region is presented in the figure below:
!!! Magnets and thin or filiform region
Everything that was previously stated concerns the massive regions (volume regions in 3D / face regions in 2D).
Generally speaking, the models for magnets cannot be used in thin or filiform regions (3D exception: see next block).
3D exception
In 3D, it is possible to use the magnet models in thin regions (face regions).
| During … | the user chooses … |
| the creation of thin region | the direction of magnetic flux:
| the orientation of magnet | the direction of magnetization: see previous block |
In order to avoid any problem of coherence on the direction of the magnetic flux, it is advised to use the option “no restriction on the direction of the magnetic flux”.
